Perform this procedure to display information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
- Select Energy Saver.
- Select the EEE Statistics tab.
- Optional: Select Clear Stats to clear information about EEE statistics.
EEE Statistics Field Descriptions
Use the data in the following table to use the EEE Statistics tab.
| Name | Description |
| Port | Shows the port number. |
| State | Shows the state of Energy Efficient Ethernet (EEE) on the port. |
| TxEvents | Shows the EEE Tx event count for the port. |
| TxDuration | Shows the EEE Tx durations for the port. |
| RxEvents | Shows the EEE Rx event count for the port. |
| RxDuration | Shows the EEE Rx durations for the port. |
